This was no offence, Chad...for an early N build mixed with M-stuff Velocity runs great and I was aware that there are some bugs, I'm fine with it.
Time service fixed next build. Grabbed the apk from NP5.
Many thanks for that [emoji3] [emoji106]
I just clean flashed...time/date issue is still there. Must be apk signing or permission issues. Hopefully N binaries will fix it.
[QUOTE = "ctfrommn, post: 156894, member: 2957"] https://drive.google.com/file/d/0BzX_bR…iew?usp=sharing [/ QUOTE]
Running great here in the United States Verizon! I just installed it, but network works, date/time work, camera works, Bluetooth works. So far, so good! -
Date/time isnt the issue per say, its when you first boot before it connects to the network that the date/time isnt correct. As soon as it connects all is fine. This should be resolved when we have N binaries.
GApps sign in fixed for next build.....lots of new stuff added as well. Faster again, reboot menu, OMS for all you theming types, bunch of underhood stuff. Should be up in a bit....just testing stuff now.
Add expanded desktop to the list....
Sounds like OMS is still a WIP so I doubt this works right now. Ill keep track of the changes as they come.
Ok, I would think about clean flashing this one.....
https://drive.google.com/file/d/0BzX_bR…iew?usp=sharing -
Thanks for the update, initial setup went flawless. Doing my setup now...feels very snappy.
@ctfrommn Thx for next update, every build feels snappier and snappier!! I don't know what you are doing but it's always superb!!!
Gesendet von meinem Nexus 6
Secret sauce
2 build day....speed dial contacts pictures fixed and more kernel additions
Secret sauce
https://drive.google.com/file/d/0BzX_bR…iew?usp=sharingInstalled the Rom, works perfect. Going to give it a run but so far all working great.
Thanks for sharing your work. -
I am missing the lockscreen. Was it removed from by google?
Not sure what you mean. Works perfectly here.
My screen is set to go to sleep after 30 seconds. Normally when i then use the power button i get onto the locscreen first and have to swipe up to get to my homescreen. Now when i push the powerbuttn when the phone is asleep i go straight away to my homepage.
Hope this makes it a bit clearer.
Funktioniert Substratum mit der Rom?
I understood what you said, but Ive never seen anything like that nor has anyone else.
Works substratum with Rome?
Substratum is a WIP for N....no roms have it working correctly yet. Im adding the new commits today though so hopefully. I will say.....if this causes me any issues Im removing it and not messing with it anymore. I will never use this and wont spend time dealing with issues with it. -
