Update: clean flashed velocity with open gapps 4/13 stock package (w/ custom install config) and it restored my apps and data all fine. running good.
ROM] [N] [7.1.1] Velocity angler
Awesome, Im glad Angler is working at least. Shamu is a port at this point so not surprising there are issues. Hopefully the new Android One is all its rumored to be. I need to get something newer this year.
Hello my friend! I recently found your Rome on AFH just by accident about a month ago. I just want to tell you how fantastic your work is! My angler has never run so well, and the battery life and customizations are just perfect. Really like the way you did not overdue the features like many other roms do. I hope you will continue your work on anglers, and I thank you very much for your hard work
I clean flashed using the Mini Dynamic Gapps (only ones I knew for sure were working with 7.1.2 ROMs at the time) and have no issues at all. The issue I had in the previous build where the Google app was freezing is also gone now. All is good!
quick question: do u plan on shipping ROM with Google keyboard instead of aosp keyboard?
Nope... Readily available in gapps or store
New build time
New build, changelog, blah blah blah......
changelog looks awesome.
Builds are in final testing. If no issues expect them soon.
Final testing were::
hope that means............awesome.
It should be decidedly above average
Ran into some fairly significant issues after rebasing. I may have to start fresh again. Hopefully I can sort this out, but not sure at this point.
damn F***....hopefully, soon.
I had to rebuild fresh from source....will be a bit before this is all back to where it was.
New build inbound. See changelog. This build is noticeably faster.
New build inbound. See changelog per usual. Dirty flash is fine.
New build inbound. Big changes this time. Clean flash recommended, especially for the full force of this build. See changelog as usual. No more need to flash a separate root app as Magisk is now built in. This build is significantly faster than previous ones.
@ctfrommn any chance Velocity Oreo will come back for angler and bullhead?
