Hier noch der Link zur neuen Version
[ROM][5.1.1][Shamu] Euphoria-OS
Tut mir leid, ich kann dir dazu leider nicht weiterhelfen.
Thread ist up2date!
Thread ist wieder aktuell.
Und schon wieder ein Update.
Alright guys, new build pushed to the site. Changelog is available in the 2nd post. I'll summarize it here after church. You can find all of these links in your OTACenter app too.
Franco hotplug is now replaced with blu_plug from Code Blue. It runs really well. I'll post my settings later as well. I'd suggest using THIS app, Kernel Adiutor, to tweak things. It's awesome, show the developer some love! @Grarak
On a side note, the TOP thanked post in this thread only has 20 thanks, that's a bit low. For 950 downloads on last build. Let's see how high we can get this one
Thanks guys! Enjoy!
Edit. Sorry guys I'll fix the in app changelog after church. For now use this http://fs1.androidfilesharing.com/ota/
Changelog gibts HIER -
Update
Thread wird in den nächsten Tagen angepasst.Zitat von dsmitty166New build is up
Minor release. Changelog in otacenter.
-lk updates
-ability to block sensor_ind wakelock in lkconfig
-cleaned up tiles
-added a patch for wireless charging sound to match the same preferences as charging Sounds
-bioshock & Wheatley governors
-double tap to wake control in settings
-Cpu now displays correct in about phone -
Thread ist aktuell.
It's update Time!
ZitatZitatNew build is on the main site, and in your OTA app, i'll upload it to AFH in a bit.
- leankernel updates to 1.14
- new lkconfig options - cpu freq control, wlan_rx & msm_hsic wakelocks - setup selinux mode for kernel
- added support for flar's new wake gestures app, check his thread for the app
- blu_plug updates: remove input boost, 2 cores always online by default
- Clear all apps button center option
- Re-add statusbar ticker
- Various bug fixes
- Translations updated -
Thread ist up2date!
Heute Abend Teste ich mal diese Rom, hat von euch wer das Neuste Build drauf? Fals ja mit welchem Kernel?
Bin zwar gerade nicht auf diesem Rom, aber Euphoria hat einen modifizierten LeanKernel mit an Bord (mit Blu-plug)...ansonsten kann man sich den Kernel seiner Wahl dazu flashen.
Neues Update ist raus, Changelog folgt später: Nightlies
Danke @Berlino
Hat irgend wer die jetzt mal wieder ausprobiert? Bin eigentlich von den letzten 4.4.4 Versionen geheilt, weil die sooo verbastelt waren... -
Nee, ich beobachte zwar den Thread, aber bin gerade auf SimpleAOSP mit Layer...seit ich mal Probs mit Themes hatte, bin ich von der CM Theme engine wieder abgekommen - Layer sind unkomplizierter und ja jetzt auch in meiner Grufti-Lieblings-Farbe erhältlich.:P
Aber was ich so mitgelesen habe, betrifft wohl u.a. Ambient Display...
War auf dem n4 damals meine Lieblings_ROM... Aber cm theme engine ist mittlerweile für mich auch No-Go
Wenn CM mal die Bugs ausgebügelt hat, ist die Theme engine schon ne schnelle einfache Sache...aber mittlerweile ist die Handhabung der Layer so komfortabel und auch einfach geworden, wo auch kaum/keine Fehler auftreten, dass diese Lösung erst mal für mich das Mittel der Wahl ist.
Wenn dsmitty das mit der blinkenden LED hinbekommt, probiere ich das Euphoria evtl. mal wieder...
Angeblich soll ja die originale cm auch blinken...aber habe ich noch nicht hinbekommen...Du etwa?
Habe bisher von keinem CM-basierenden Rom gelesen, dass das mit dem blinken der LED klappt - das einzige Rom, wo es funktionieren soll, ist die MeanPop-Rom auf Stock-Basis (aber wohl auch nur mit dem Stock-Kernel)...
Die MeanPop kann wohl auch die LED blinken lassen.
Und die ist Stock 5.0.1 -
