Da isssssa!!!
Nun hat das N9 auch ein Franco.Kernel... zwar noch eine Beta und noch ohne original Thread aber das kommt noch alles.
Kernel erstmal nur als boot.img Datei verfügbar!
Hier der g+ Beitrag von Franco:
QuoteDisplay MoreAlright I decided to take the plunge and work a little bit on the Nexus 9.
Couple important things before you flash it:- FKUpdater does not "officially" supports this device (at least not yet) because I wasn't planning on working for it
- I reserve the right for not providing regular updates because I don't have time, I said from the beginning that I wouldn't work on it and because I don't have a big emotional attachment to tablets in general. I'll deflect any attempt to convince me, ask me or bully me to release new Kernels for the Nexus 9
- This first release is only a boot.img, so don't ask me for a flashable zip. If you were interested in FK for this device in the first place I trust you know how to use fastbootThat said, be assured that I will make FKUpdater compatible with it in the future.
Also this release is mainly aimed for:- Improving general tablet performance (no more 2 second delay after opening an app which happened sometimes before)
- Improving performance for encrypted devices (both read and write IO)
- Improving battery life by using more intelligent cpu boost on touch events
- Using Conservative as the default governor for improved cpu frequencies usage homogenization and fast ramp up, fast ramp down
- Improved lowmemorykiller driver to reduce random app killing by Android and therefore reduce/remove re-draws
- An as always a lean build without most of the usual debug crap that vendors never disableI'm very interested in real world testing of this Kernel against stock Kernel (I don't really care if it benches higher or lower than stock), battery life and heat level close to the camera lens.
I'll open up a thread on XDA sometime today.
Give me your feedback by posting below.
#francoKernel
Download:
boot.img - http://kernels.franco-lnx.net/Nexus9/5.0/
To flash go to the bootloader and then fastboot flash boot boot-r1.img
Happy Flashing...
