Update auf 2.04 auf Basis LMY47M (T-Mobile USA):
ZitatAlrighty. 2.04 is up, based on LMY47M. I built it in such a way that I believe it will be compatible with all carriers including T-Mobile. As outlined in post 1, I recommend T-Mobile customers flash the LMY47M bootloader/radio and everyone else flash LMY47E bootloader/radio (links to both in the OP). Then just flash the ROM.
This build is certainly working flawlessly for me on Verizon, but please report back if you see anything odd with your carrier and be sure to include which carrier you have and which bootloader/radio you used. The way I built this, I believe it might fix some issues with T-Mobile while not interfering with any other carriers. It is worth flashing this if you've had black screen issues to see if it fixes that, but I do not expect LMY47M to fix black screen issues. The more I look into that problem, the more I think it's an app that a few people have installed that is not playing nicely with 5.1. But we'll get into that once we find out if 2.04 actually makes any difference WRT the black screen problem; there's a chance since some vendor binaries were updated, including some sensor libraries. That said, this change to LMY47M is more for compatibility's sake: to have one base that is designed for all carriers.
- T-Mobile (nur USA) users use the LMY47M bootloader/radio (flash via TWRP - thanks @scrosler)
- Everyone else use the LMY47E bootloader/radio (batch file: flash via fastboot - thanks @scrosler)
